waylander314159
Sep 21, 2019Follower
How To Stop Netgear Armor Vulnerability Scan on a device
The Netgear Armor scan is wasting paper on my printer. Apparently it does it's weekly scan, and the printer thinks a print job is starting. I want to disable the internal scan at least for that dev...
ScottH409
Dec 28, 2019Aspirant
This is still happening - even after I removed the printer from the scan like someone suggested. I've probably wasted 60 pieces of paper at this point. I have the new firmware and I've worked with your case management team, Netgear. When are you going to solve this problem?
Help! My last case was 42028998.
Scott H.
Glenvis
Dec 28, 2019Star
Scott, you are not alone. I've done the same thing with the same results. I finally gave up and disarmed Netgear Armor ("circle house" in upper left corner, settings, security, uncheck Enabel NETGEAR Armor - done). I'm paid up until next July, but the extra problems aren't worth it. I love the Orbi system, the Armor add-on isn't what it should be.
Scan night for me is Saturday, I'll let you know if disabling Armor did the trick.
Glenvis
- PhysicsWorldDec 28, 2019Guide
Hi Glenvis:
Same issue here with all four printers I have installed in my home. First, I worked with their technical support to install a beta version of the firmware without much success. Then I changed the IP address of one of my printer and it still continued having the same issue. Finally, and as per the recommendation of Armor, I removed the printers from Armor scanning, and they still printed the dreaded 3 pages. The only remaining step left for me is to disable Armor the way you described it in your post.
But I do not believe we should stop here, we should ask for a refund. The minimum they should do is extend the expiration date of every affected member until the issue is resolved.
Thank you.
- GlenvisDec 29, 2019Star
Test pages no more. Got up this morning and checked my printer, no test pages - for the first time in several months. Disabling Armor was the only cure that worked.
Sorry Netgear, but until Armor is fixed I won't be participating.
- DexterJBFeb 06, 2020NETGEAR Moderator
Hi all, this is still being worked on by engineering. We will provide an update once available.
Dexter
- LtZeeFeb 17, 2020Initiate
Hi,
Please add me to the list of people eagerly awaiting the fix for this!
