waylander314159
Sep 21, 2019Follower
How To Stop Netgear Armor Vulnerability Scan on a device
The Netgear Armor scan is wasting paper on my printer. Apparently it does it's weekly scan, and the printer thinks a print job is starting. I want to disable the internal scan at least for that dev...
Glenvis
Dec 28, 2019Star
Scott, you are not alone. I've done the same thing with the same results. I finally gave up and disarmed Netgear Armor ("circle house" in upper left corner, settings, security, uncheck Enabel NETGEAR Armor - done). I'm paid up until next July, but the extra problems aren't worth it. I love the Orbi system, the Armor add-on isn't what it should be.
Scan night for me is Saturday, I'll let you know if disabling Armor did the trick.
Glenvis
PhysicsWorld
Dec 28, 2019Guide
Hi Glenvis:
Same issue here with all four printers I have installed in my home. First, I worked with their technical support to install a beta version of the firmware without much success. Then I changed the IP address of one of my printer and it still continued having the same issue. Finally, and as per the recommendation of Armor, I removed the printers from Armor scanning, and they still printed the dreaded 3 pages. The only remaining step left for me is to disable Armor the way you described it in your post.
But I do not believe we should stop here, we should ask for a refund. The minimum they should do is extend the expiration date of every affected member until the issue is resolved.
Thank you.
- GlenvisDec 29, 2019Star
Test pages no more. Got up this morning and checked my printer, no test pages - for the first time in several months. Disabling Armor was the only cure that worked.
Sorry Netgear, but until Armor is fixed I won't be participating.
- DexterJBFeb 06, 2020NETGEAR Moderator
Hi all, this is still being worked on by engineering. We will provide an update once available.
Dexter
- LtZeeFeb 17, 2020Initiate
Hi,
Please add me to the list of people eagerly awaiting the fix for this!
- studiodbFeb 17, 2020Guide
One of Netgear's techs (Oliver) helped me download and install the newest version ( 2.5.1.8.) of their Armor software. Inititally, I could find NO update for firmware OR software until Oliver showed me where it was hiding. (None of my equipment showed my software as needing to be updated.) Since I installed it, I have had no printing issues whatsoever. That was on Feb. 12, 2020. I have run several scans since then with no unwanted printing. I'll feel better once a full week or two have gone by without those extra pages coming off the printer, but for now, it does seem that the issue has been resolved.
