waylander314159
Sep 21, 2019Follower
How To Stop Netgear Armor Vulnerability Scan on a device
The Netgear Armor scan is wasting paper on my printer. Apparently it does it's weekly scan, and the printer thinks a print job is starting. I want to disable the internal scan at least for that dev...
dyard
Jan 29, 2020Aspirant
I am having the same issue. I cant turn on off this armor. Its blocking lots of my devices. I see the option on my phone but it times out. When I login the computer I cant find any options to disable it.
DexterJB
Jan 29, 2020NETGEAR Moderator
Hi dyard, the Armor feature does not have the option to block devices. Are your devices unable to connect to the network or is it blocking certain websites? Have you tried using another device where you have the app (Orbi or Nighthawk) installed to turn off the Armor feature?
Dexter
