waylander314159
Sep 21, 2019Follower
How To Stop Netgear Armor Vulnerability Scan on a device
The Netgear Armor scan is wasting paper on my printer. Apparently it does it's weekly scan, and the printer thinks a print job is starting. I want to disable the internal scan at least for that dev...
ablots
Feb 01, 2020Aspirant
Does anyone have a solution for this problem? My firmware is current and the issue still persists.
Glenvis
Feb 01, 2020Star
Take a look at message 36. This is how I stopped Netgear Armor. Haven't had a problem since.
Good luck!
- ablotsFeb 03, 2020Aspirant
Thanks!
- beautifieJul 10, 2020Aspirant
So I have witnessed this as well, I just so happen to witness it when my son gets DDoS online from a gamer.
I just disabled port 9100 in my printer by using the printers IP and a web browser. Here is some more information on port 9100 and why you shouldn't use it.
http://hacking-printers.net/wiki/index.php/Port_9100_printing
You can find more information by googling your printer and how to disable port 9100.
