DannyLin
May 27, 2020Apprentice
How to stop RAX120 keeps blocking my streaming service
I have recently purchased the RAX120 router and experienced an issue. I'm constantly using a streaming service from https://tw.iqiyi.com And Netgear Armor keeps blocking the streaming URL, h...
- May 28, 2020
How do I turn NETGEAR Armor on or off using the Nighthawk or Orbi app?
Joi007
May 27, 2020Tutor
Yes, it appears to be blocked by Bitdefender. You'll have to write support at Bitdefender if it is a false positive to see if they app will let it through.
I guess you could also try to disable the protection and see if it lets you access that site?
See attached
Joi007
May 27, 2020Tutor
