DannyLin
May 27, 2020Apprentice
How to stop RAX120 keeps blocking my streaming service
I have recently purchased the RAX120 router and experienced an issue. I'm constantly using a streaming service from https://tw.iqiyi.com And Netgear Armor keeps blocking the streaming URL, h...
- May 28, 2020
How do I turn NETGEAR Armor on or off using the Nighthawk or Orbi app?
Joi007
May 27, 2020Tutor
Yes, it appears to be blocked by Bitdefender. You'll have to write support at Bitdefender if it is a false positive to see if they app will let it through.
I guess you could also try to disable the protection and see if it lets you access that site?
See attached
DannyLin
Joi007 wrote:Yes, it appears to be blocked by Bitdefender. You'll have to write support at Bitdefender if it is a false positive to see if they app will let it through.
See attached
I tried to disable the Netgear Armor but unfortunately I can't find a way to do it. There's no option on the RAX120 admin console that I can disable it. It just says ENABLED.
I checked the discussions, and appeartly Orbi users can disable it via their Orbi app. But I just can't find such an option on my Nighthawk Wifi app for RAX120.
It would be great if you can shed some light on this.
- michaelkenwardMay 28, 2020Guru - Experienced User
I checked the discussions, and appeartly Orbi users can disable it via their Orbi app. But I just can't find such an option on my Nighthawk Wifi app for RAX120.It would be great if you can shed some light on this.
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might do better to try there.
- Joi007May 28, 2020Tutor
- DannyLinMay 29, 2020Apprentice
Joi007 wrote:How do I turn NETGEAR Armor on or off using the Nighthawk or Orbi app?
Thanks a lot. Finally found how to turn it off. Pity it cannot give a hall pass to specific applications.
- Joi007May 29, 2020TutorRe: How to stop RAX120 keeps blocking my streaming service
No worries please mark thread as solved.
