DannyLin
May 27, 2020Apprentice
How to stop RAX120 keeps blocking my streaming service
I have recently purchased the RAX120 router and experienced an issue. I'm constantly using a streaming service from https://tw.iqiyi.com And Netgear Armor keeps blocking the streaming URL, h...
- May 28, 2020
How do I turn NETGEAR Armor on or off using the Nighthawk or Orbi app?
DannyLin
May 28, 2020Apprentice
Joi007 wrote:Yes, it appears to be blocked by Bitdefender. You'll have to write support at Bitdefender if it is a false positive to see if they app will let it through.
I guess you could also try to disable the protection and see if it lets you access that site?
See attached
I tried to disable the Netgear Armor but unfortunately I can't find a way to do it. There's no option on the RAX120 admin console that I can disable it. It just says ENABLED.
I checked the discussions, and appeartly Orbi users can disable it via their Orbi app. But I just can't find such an option on my Nighthawk Wifi app for RAX120.
It would be great if you can shed some light on this.
Joi007
May 28, 2020Tutor
- DannyLinMay 29, 2020Apprentice
Joi007 wrote:How do I turn NETGEAR Armor on or off using the Nighthawk or Orbi app?
Thanks a lot. Finally found how to turn it off. Pity it cannot give a hall pass to specific applications.
- Joi007May 29, 2020TutorRe: How to stop RAX120 keeps blocking my streaming service
No worries please mark thread as solved.
