wuzcsg
Oct 10, 2020Tutor
How to turn off Netgear Armor?
Hi, My model is Nighthawk RAX20 Dual-band AX4 WiFi 6 Router - AX1800 and I just changed from Google Wifi. After changed the RAX20 I found something strange. I can't turn off the Netgear Armor....
michaelkenward
Oct 11, 2020Guru - Experienced User
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might like to try there too.
The rest of your message is a bit hard to follow.
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
- shadowsportsOct 11, 2020Hero
Greetings,
How to turn it off:
You can also do it in the router's GUI itself.
How to cancel it:
https://kb.netgear.com/000059446/How-do-I-cancel-my-NETGEAR-Armor-subscription
Which will ultimately lead you here...
