wuzcsg
Oct 10, 2020Tutor
How to turn off Netgear Armor?
Hi, My model is Nighthawk RAX20 Dual-band AX4 WiFi 6 Router - AX1800 and I just changed from Google Wifi. After changed the RAX20 I found something strange. I can't turn off the Netgear Armor....
Christian_R
Oct 12, 2020NETGEAR Employee Retired
Hello wuzcsg,
May you refer to the articles provided by shadowsports and let me know if your issue persists. You may also try reinstalling the Nighthawk app and power cycling your router.
Christian
