Rvadnerker
Sep 05, 2023Aspirant
How to unblock a app on RAXE500
Hello, I have a android streaming device that I use currently and have been for quite some time. I downloaded a app, that I know is trustworthy because many of my friends have been using it for quite...
michaelkenward
Sep 05, 2023Guru - Experienced User
Rvadnerker wrote:
I have a two part question, how do I reset the questions and answers that allow me to log into the router as admin and how can I tell the router to give this app access.
The answer to first question depends on if you have forgotten the password you set for admin to get into the browser graphical user interface. (Look on the label for the defaults.) Did you set it up to allow password recovery? If so, try to get in and it will take you through the process.
If you have forgotten the password and answer, your only option is to reset the device.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
As to the app access, I doubt of the router is in any way involved in blocking that.
Or do you have some evidence that the RAXE500 is culpable?
- RvadnerkerSep 05, 2023AspirantHi,
Thank you for your reply, I do not believe I used the password recovery and I just may have to reset my router, which is not my first choice to do.
I am adding the security threat block from the app yesterday, it is the router blocking access. Thank you and any help is always appreciated.
Rvadnerker- michaelkenwardSep 05, 2023Guru - Experienced User
Rvadnerker wrote:
I am adding the security threat block from the app yesterday, it is the router blocking access. Thank you and any help is always appreciated.Your first message said nothing about using Armor. That is different from the router.
Armor sits between the router and the Internet.
Thank you for your reply, I do not believe I used the password recovery and I just may have to reset my router, which is not my first choice to do.Did you change the password for admin? If not, you may be able to get in.
- RvadnerkerSep 05, 2023AspirantMy apologies, I wasn’t sure about Armor. So is there a way to let Armor not block thru my phone? I did not change the password for admin, I’m at work right now. Not sure if it’s good/safe to try on my phone.
Rvadnerker
