Rvadnerker
Sep 05, 2023Aspirant
How to unblock a app on RAXE500
Hello, I have a android streaming device that I use currently and have been for quite some time. I downloaded a app, that I know is trustworthy because many of my friends have been using it for quite...
Rvadnerker
Hi,
Thank you for your reply, I do not believe I used the password recovery and I just may have to reset my router, which is not my first choice to do.
I am adding the security threat block from the app yesterday, it is the router blocking access. Thank you and any help is always appreciated.
Rvadnerker
Rvadnerker
michaelkenward
Sep 05, 2023Guru - Experienced User
Your first message said nothing about using Armor. That is different from the router.
Armor sits between the router and the Internet.
Did you change the password for admin? If not, you may be able to get in.
- RvadnerkerSep 05, 2023AspirantMy apologies, I wasn’t sure about Armor. So is there a way to let Armor not block thru my phone? I did not change the password for admin, I’m at work right now. Not sure if it’s good/safe to try on my phone.
Rvadnerker- RvadnerkerSep 05, 2023AspirantHere is a screenshot I just took from my phone, Armor did not find any threats. Either Armor is not working properly or something is wrong with the app.
Rvadnerker- michaelkenwardSep 05, 2023Guru - Experienced User
Rvadnerker wrote:
Either Armor is not working properly or something is wrong with the app.Looks like a good diagnosis to me.
You might like to try it on the Armor bit of this community.
NETGEAR Armor - NETGEAR Communities
