Chowman13
Oct 28, 2019Aspirant
How to update firmware
I'm trying to boost the signal strength on my extender. I've never updated the firmware and probably need to start there. How do I update the firmware? I click on the download, but all I get is a ...
DarrenM
Oct 28, 2019Sr. NETGEAR Moderator
Hello Chowman
Here is a link to a helpful KB on how to update the extender and also a link to the latest firmware for the extender.
https://kb.netgear.com/000057115/How-do-I-update-the-firmware-on-my-NETGEAR-WiFi-Range-Extender
https://kb.netgear.com/000060287/EX2700-Firmware-Version-1-0-1-52
Thanks
DarrenM
- Chowman13Oct 28, 2019Aspirant
Darren,
Still doesn't help me. The instructions make no sense and the link for firmware update just download a image file. On top of that I get an error message that the image file is corrupt?
- plemansOct 28, 2019Guru - Experienced User
The firmware update link with instructions that DarrenM linked to even has a video. did you watch it? It walks you through the update.
And you do need the image file but you need to make sure you have extracted it from the zip file you downloaded. I just did this just to make sure it was good and everything worked for me.
so:
1. download the file
2. Extract it.
3. Use this extracted file for the upload.
