HSGehlar
Dec 19, 2020Aspirant
I cannot remotely access my Apple Home devices and Q-See cameras after installing ARMOR Security
I have ORBI RBR50 AC3000 Tri-band router, recently updated to firmware V2.5.2.4 and enabled Security. Now I cannot remotely access my Apple Home devices and Q-See cameras after installing Armor Security on ORBI. When I'm home they all work fine. I rebooted/reset everthing, that did not help. Any idea? Your help is appriciated.
1 Reply
You can check whats being blocked in the armor dashboard and unblock things.
- Launch the Nighthawk app from a mobile device that is connected to your router’s network.
- Tap Security.
The NETGEAR Armor dashboard displays. - Tap the Threats card.
A list of suspicious blocked URLs displays. - Tap on the URL that you want to unblock.
- Tap Add to Unblocked.
A warning displays. - Tap OK.
