dschio
Sep 26, 2025Follower
I did not ask for and do not want Armor
I have been using Netgear routers for a long time, but my most recent purchase of a Nighthawk RAXE300 apparently came with and installed "Armor". I did not ask for this, and I do not want it. It is...
Sep 26, 2025Guru - Experienced User
So if you don't want it then you can factory reset the router and setup from scratch with a PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Do not use NH app to set it up.
You can adjust Armor for sites to allow as well:
Armor Help and Information FAQ | NETGEAR Communities
What is not working on the iphone with the app? Not loading or what is not working on the iphone? Iphone model #? What iOS version is on the iphone?
NH app is working on my iphone 12 Pro max.
Try the NH app on a different device, Android or different Apple device.
