WinterMute
Aug 05, 2020Star
Interacting with Armor once it's enabled
Turning on Armor killed my home network (Modem/Internet was fine) until a power cycle. This router has never had a connection break like that--my ISP has outages from time to time, but this is th...
WinterMute
Aug 07, 2020Star
Thanks Christian_R:
It's a RAX200, firmware 1.0.2.98, and I've set up a ticket with support. I didn't realize at first that there's a particular way to walk through Support --> Other --> Armor that will let you get support without paying for out-of-warranty support.
With luck this will solve the problem, but I think long-term there needs to be some sort of logging or visibility so the user (who, if they're looking for logs and inside the router or the Armor portal, is already a pro-level user) can have the ability to address what's causing the problem.
WinterMute
Aug 27, 2020Star
Christian_R just letting you know I have updated details at https://community.netgear.com/t5/NETGEAR-Armor/Share-Your-NETGEAR-Armor-Experience/m-p/1863299/highlight/false#M2686
For anyone else running across this thread, my Support Ticket didn't really go very far before I gave up on it, removed Armor, and also uninstalled all BitDefender products (a different but related topic).
If anyone is curious about the details, feel free to stop by the link above or ask me here and I'll try to keep an eye on any updates to this thread.
Thanks, and best of luck to those trying to work with Armor.
- Tommyhuynh87Jan 19, 2021Aspirant
Hi all,
After about a week turn off Armor on my RAX80 the Wifi speed get back to the where it was and no more killing wifi connection and low Wifi speed. ( Around 750Mps over Wifi6). So Now I 100% sure when you enable the feaking Armor on your router , it will kill your wifi and your devices connection. I have to turn it off by use the netgear app and email Bitdefender Support Center to remove it out of my router and canel it. Here is how you can do:
open netgear app on your phone. In the top-left corner, tap the Home or Cloud icon.
Tap SETTINGS > Securit and tap the Enable NETGEAR Armor slider to turn NETGEAR Armor off
After that do hard reset on the router :
- Have the router powered on make sure it fully bootup.
- press down the Restore Factory Settings button and hold it for about 7 to 10 seconds
- When the power light starts to blink you can release the reset button and wait for the router to start up ( you can count it blink about 5 time and then release the reset button)
On my RAX80 I dont need to downgrate the firmware to make it work. just do hard reset and that's good to go. the Wifi speed will getting better about an hours or so
REMOVE ARMOR out of your router
1.Login into your netgear account https://armor.netgear.com/2.Click on the 3 horizontal lines in the left corner of the page3.Select MyRouters-Click on the Router that needs removal4.Provide us with the router_id that can be seen in the main search bar of your browser (should look like router_id =259xxx0xxxx)One is importan thing if your computer installed bitdefender you should try this one:https://www.bitdefender.com/consumer/support/answer/3766/Or remove it out of your computer. ( I remvoed it out of all my device )I hope this will help you guys.
