mapping
Sep 27, 2023Aspirant
Internet Radio stations blocked on AX2400 / RAX30
My RAX30 is blocking my Naim ND5XS from accessing some internet radio stations. These stations are available on other devices – only the Naim is blocked (they all worked on the Naim before changing t...
Sep 27, 2023Guru - Experienced User
What happens if you disable Armor temporarily in the NH app?
Select the 3 horizontal bars top left corner, then select Settings/Security then move the slider button to disable Armor.
