mapping
Sep 27, 2023Aspirant
Internet Radio stations blocked on AX2400 / RAX30
My RAX30 is blocking my Naim ND5XS from accessing some internet radio stations. These stations are available on other devices – only the Naim is blocked (they all worked on the Naim before changing t...
mapping
Hi - with Armor disable the radio blocking station continues.
Sep 27, 2023Guru - Experienced User
With Armor and any other security app (Smart Parental Controls or Access Controls) disabled, power off for 1 minute then back ON with the ISP modem and router.
Turn off and unplug modem.
Turn on computers and rest of network.
