Gary_A
Jun 01, 2019Guide
Is Armor activated or not?
Armor.netgear.com website shows I have a subscription. The IOS App shows the tile for Armor as expired, clicking it takes me to a screen to renew my subscription, clicking to renew takes me to the A...
Gary_A
Jun 03, 2019Guide
I called support at Bitdefender and they have escalated it to a level 2 as the tech could not figure out the reason the the orbi app or router is not seeing that Armor is activated. Great tech, understood the problem but just couldn't fix it. Netgear really needs to take some ownership in this but knowing that they only provide 90 days of support via phone or e-mail after pruchase means I don't want to call and be told I have to pay for the call. I will update this thread once I see what Bitdefender does.
Gary_A
Jun 04, 2019Guide
Bitfender resolved my issue and Armor shows actived in the app and router now. I recommend contacting them at https://www.bitdefender.com/consumer/support/
- Christian_RJun 24, 2019NETGEAR Employee Retired
Hello Santap,
We have also noticed an issue. If you believe that your expiration date on the status is not accurate, please DM me with your serial number/email address and we will look into it for you.
Gary_A - Glad to hear you were able to get it resolved. Also, thanks for posting an update on the thread as it may help others who may experience the same issue.
~Christian
- EinrichAug 04, 2019Star
I have the exact same issue (on latest router firmware and latest android app). When I go deep to the Netgear Armor page (black background), it shows that I have 323 days left on my subscription.
Obviously - I paid to renew.
Except that something went wrong during the renewal in the router and in the app, as there the Armor still shows respectively there as Not Activated and as Expired...
It's only when I click renew in the app (which is stupid as I already renewed) that I am prompted for a licence (which of course I already used) but then I am sent to the Armor Page and where everything is fine...
What must I do to fix this? I contacted bitdefender who told me I ha to contact netgear (which I did)...
2 months later, 5 reminders later, there's nothing on my ticket.
No answer, no reply, no action. Just personal frustration over what seems like a good product.
If support can / wants to look at it, I can give them my info. In the meantime, I feel ripped-off.
I have also done a check... Since Armor is "considered active" in the black armor page, I decide to try to download a test malware file. Of course, for that I had to disable bitdefender and its associated url defender in my browser. I could then download the sample EICAR test file.
This shows that if the router states the armor is not activated, then it's not working to protect those device on your network that do not have antivirus (think your tv, your game console, cameras, etc).
This also shows that the "trial activation" and "renewal" features of both the ORBI APP (and the lack of management features in THE ROUTER) are an issue. As soon as both don't sync properly, and if you have used up a licence, then you are effectively in trouble.
Customer support can't handle this well, as the licences are not issued by them but via B2B2C from Bitdefender. You being a C (a customer) can't really get support from B (netgear) while the other Business (Bitdefender) asks you to work with them.
Senior Management at Netgear, in the product dev, should look into it.
