Gary_A
Jun 01, 2019Guide
Is Armor activated or not?
Armor.netgear.com website shows I have a subscription. The IOS App shows the tile for Armor as expired, clicking it takes me to a screen to renew my subscription, clicking to renew takes me to the A...
Wisconsingal
Oct 23, 2019Tutor
Thanks I'll give that a try..
I work in the Tech support/customer service industry and this type of scenario is a bit ridiculous. By now their should be specific steps to resolve it listed somewhere publicly for paying customers or at the very least general steps customers were expected to follow to resolve it.
. You mentioned that you called them and they had it resolved quickly, what was done to resolve it?
Wisconsingal
Oct 26, 2019Tutor
Hi,
I did put a call into Bitdefender, the customer support team member was not able to fix the issue or identify the root cause so he opened up a case and forwarded it to their Tech Support team. While waiting for Tech support, I was able to resolve the issue on my own. I ended up doing a factory reset on the router and re-enabled/activated Armor security. App now shows it's Activated.
- TheFloridianJan 26, 2020AspirantHi All,
Rebooting the router fixed the issue on my end. Hope it works for you.
TheFloridian
