Gary_A
Jun 01, 2019Guide
Is Armor activated or not?
Armor.netgear.com website shows I have a subscription. The IOS App shows the tile for Armor as expired, clicking it takes me to a screen to renew my subscription, clicking to renew takes me to the A...
Wisconsingal
Oct 26, 2019Tutor
Hi,
I did put a call into Bitdefender, the customer support team member was not able to fix the issue or identify the root cause so he opened up a case and forwarded it to their Tech Support team. While waiting for Tech support, I was able to resolve the issue on my own. I ended up doing a factory reset on the router and re-enabled/activated Armor security. App now shows it's Activated.
TheFloridian
Jan 26, 2020Aspirant
Hi All,
Rebooting the router fixed the issue on my end. Hope it works for you.
TheFloridian
TheFloridian
