Malis
May 01, 2021Follower
IS ARMOR NEEDED?
Just upgrade my wifi. It comes with a subscription to Armor but I'm not sure if its just redundent. I also have a subscription to Total AV and run Norton VPN. MAC desktop, iphones, ipad. Thanks Tim. (An analog brain in a digital world.)
1 Reply
Is it needed?
Only as much as you think it is.
Same with any antivirus suite.
If you've got coverage and are happy with it, then I wouldn't worry about it.
If you're not happy with what you've got or just want to see how well Armor works, then use the trial and see how well it works.
