rkruz
Feb 28, 2022Apprentice
Is Armor reported locks sourced from devices on my LAN?
RAX43, Windows 10 Im getting messages from Netgear Armor every few hours, "NETGEAR Armor detectedd that NVR House Cameras attempted a connector to a suspicious remote locate 42.96.185.60 and blocked...
Feb 28, 2022Guru - Experienced User
Some of the NVR's communicate back with the manufacturer's servers for updates/time checks/etc.
It could be that happening. Some of the basic settings could be blocking that check.
Is the NVR having any issues or working as it should?
If its working as it should, I wouldn't worry to much about it.
- rkruzFeb 28, 2022Apprentice
This NVR has gotten hacked at some point. I know this because some of the Camera names were changed to "f...ck Biden" and some other things changed. Further, I have an identical NVR and have had no blocked warnings from it. So Im sure there is some trojan on the NVR or possibly a camera. Another bit of evidence is that I turned off the NVR and the warnings stopped. Ive reset to factory settings and will monitor for block warnings and Im hoping that cleared the hack. The NVR stores video on a harddrive but I would not think there would be any hard drive data involved in the operation of the NVR but easy enough to reformatte the drive too.
Other then the obvious hack messages the NVR has worked fine.
If the reset to factory does not work, Ill replace the NVR as I have a spare one in case of failure as its hard to trust the chinese sellers will be around long enough to support.
- plemansFeb 28, 2022Guru - Experienced User
Sounds like you have it under control!
Good work!
