thisguy
Apr 13, 2019Tutor
Is there Documentation for Bitdefender Netgear Armor?
My firmware is updated to the new version that has the Netgear Armor added as a feature to my Orbi router. I activated that last night. I also installed Bitdefender on my two laptops.
I'm not a...
DexterJB
Apr 30, 2019NETGEAR Moderator
Hi thisguy, please let us know what we (NETGEAR) can improve on and also let Bitdefender know, if you are still in correspondence with them, on features that aren't working for you for them to address it on their end.
Dexter
thisguy
May 02, 2019Tutor
One simple improvement Netgear can do for the admin landing page of the Orbi firmware would be to fix the link for Armor. The shield icon appears to be a link, however, nothing happens when you click on it. I've used a few browsers to see if it was an issue with crossbrowser compatability or popup blocking but same result on IE, Edge, Chrome and Firefox. From a user perspective, it makes me think somethings wrong on my end or your end. I can't even assume what's going on. Consider doing something similar to what you do with Circle - link to a product page or link to the armor.netgear.com landing page - which I think would be a better idea because it is buried in the Bitdefender client software on users machines.
I'll post more feedback later. I need to figure out how to articulate it.
