yoop2
Jan 23, 2020Aspirant
Man in the middle warning message
I am constantly getting a message that my Wi-Fi is compromised by a "Man in the Middle" something or other. I have Bite Defender What is it? It tells me to use another network but i only have one....
yoop2
Thank you
Orbi-Roc
Jan 31, 2020Luminary
Hi yoop2 . That's Bitdefender blocking access to some URL's which BD deems unsafe. If you go to your Netgear Armor Portal, you should be able to see which sites BD blocked and follow-up with the if you're certain that some of the sites blocked are legit. BD will whitelist them. But you ought to be careful with that as hackers are very adept at hiding their true indentity and presenting themselves as a bona fine site.
