Nissanclubman
May 26, 2019Aspirant
Moving SC101 to another PC
I'm sure this is a straight forward task but just wanted to double check the procedure. Existing SC101 was working fine on a windows XP PC then PC died. I then want to setup the SC101 software o...
DexterJB
May 26, 2019NETGEAR Moderator
Hi Nissanclubman, welcome to the community. The link below may help out.
https://www.netgear.com/support/product/SC101.aspx#download
Dexter
Nissanclubman
Thanks Dexter,
I'll download the SCM and install it tonight.
Is there a thread that you can point me to that describes how to setup the drives to be visible in the SCM or will they be automatically setup?
Will start with installing the SCM software and see how things appear.
Kind Regards Richard
- DexterJBMay 28, 2019NETGEAR Moderator
This link may help but for additional resources, the link below has some helpful documents.
https://www.netgear.com/support/product/SC101.aspx#docs
Dexter
