trvlncwl
Feb 25, 2022Tutor
MR60 no longer runs scans
Armor shows last scan done 12-01-2022. Attempts to scan manually all fail.
- Feb 27, 2022
glad it worked!
If you mark it solved,it might help others as well as keeping others from trying to still fix it :)
Feb 26, 2022Guru - Experienced User
What firmware version are you on?
Have you tried a reboot?
Or factory reset?
