jerryzurek
Jul 09, 2019Tutor
Must deactivate Armor trial
Armor free trial blocks legitimate sites. I want to deactivate it and wash it from the system. How do I get rid of this annoying trial?
Jul 09, 2019Guru - Experienced User
You can't "get rid of it" because its built into the firmware. You can deactivate/turn it off though.
- macchelseaAug 08, 2019Aspirant
The turn OFF setting is not in the iPhone Orbi app. How do I turn it off then?
- DexterJBAug 08, 2019NETGEAR Moderator
Hi macchelsea, welcome to the community! Upon testing, it does appear for me. The toggle to turn it off should be there as described on the steps on the link below.
May we know what issue are you encountering with Armor? We'd be glad to help out.
Dexter
