jerryzurek
Jul 09, 2019Tutor
Must deactivate Armor trial
Armor free trial blocks legitimate sites. I want to deactivate it and wash it from the system. How do I get rid of this annoying trial?
tiarowley1
Oct 26, 2019Aspirant
hello,
this armour is blocking several of my home hub devices! help! tell my *** to cancel as i do not want to pay 69.99 for something i hate!
thanks a bunch
TR
Oct 26, 2019Guru - Experienced User
tiarowley1 wrote:
hello,
thanks a bunch
TR
Pretty sure if someone needs to "tell my *** to cancel" that'd be you. Not us. As well as I'd probably phrase it with a little more respect if you're asking someone to do something for you.
You're other option is to start your own thread as your circumstances might be a little bit different. And if they aren't follow the instructions on shutting it off that are mentioned prior.
