needhelp___
Mar 28, 2025Tutor
need technical help
A blue screen occurs due to a conflict with the A8000 product and the game's EasyAntiCheat program. I am seeking help here since the free technical support period has expired.
needhelp___
Mar 29, 2025Tutor
Because before I plugged in the Netgear product, the blue screen wouldn't pop up, and after I plugged it in, the blue screen popped up. And, what's the point of the game? It's important to use an anti-cheat program called EasyAntiCheat that turns on when the game is running.
Mar 29, 2025Guru - Experienced User
Isn't "easy anti cheat" pretty close to a virus?
Have you tried uninstalling that and running the adapter?
Or installing the stand alone driver?
- needhelp___Mar 29, 2025Tutor
Yes, of course. East Anti Cheat often conflicts with other programs, but not this time.
I tried uninstalling and reinstalling the adapter, and also checked the integrity of the EasyAntiCheat and reinstalled it.
I didn't and I don't have any information of this work, so I want you to teach me what is this.
I would appreciate it if you could tell me if it is a simple home remedy that can be done through the WIndows Control Panel. It doesn't necessarily have to be specialized knowledge.
Thank you for your interest and help.
- plemansMar 29, 2025Guru - Experienced User
Just checked and they don't have the standalone for the A8000. Are you on windows 11? or 10?If your on 11, what version?
I'm in Windows 10
