needhelp___
Mar 28, 2025Tutor
need technical help
A blue screen occurs due to a conflict with the A8000 product and the game's EasyAntiCheat program. I am seeking help here since the free technical support period has expired.
Mar 29, 2025Guru - Experienced User
Isn't "easy anti cheat" pretty close to a virus?
Have you tried uninstalling that and running the adapter?
Or installing the stand alone driver?
needhelp___
Mar 29, 2025Tutor
Yes, of course. East Anti Cheat often conflicts with other programs, but not this time.
I tried uninstalling and reinstalling the adapter, and also checked the integrity of the EasyAntiCheat and reinstalled it.
I didn't and I don't have any information of this work, so I want you to teach me what is this.
I would appreciate it if you could tell me if it is a simple home remedy that can be done through the WIndows Control Panel. It doesn't necessarily have to be specialized knowledge.
Thank you for your interest and help.
- plemansMar 29, 2025Guru - Experienced User
Just checked and they don't have the standalone for the A8000. Are you on windows 11? or 10?If your on 11, what version?
- needhelp___Mar 29, 2025Tutor
I'm in Windows 10
Try upgrading to 11. It should still be free. sometimes you have to do some trickery to get it working but it should. I've seen quite a few posts with issues on win10 and wifi adapters
