OilCan
Feb 28, 2021Guide
Netgear Armor - "Failed to subscribe"
I'm trying to activate Netgear Armor, but am getting the same message as many here: "Failed to subscribe". Tried contacting Netgear chat, but apparently the high pricetag of this router affords buyer...
- Feb 28, 2021
supports first recommendation is usually a factory reset and then reinstall. I'd try that. if it doesn't help, might try contacting netgear armor support.
NETGEAR Armor | Product | Support | NETGEAR
or bit defender armor support
NETGEAR Armor powered by Bitdefenders - Bitdefender Consumer Support Center
or maybe Christian_R can help.
Feb 28, 2021Guru - Experienced User
There's a couple different things that you can try.
they're go over them in this thread:
Netgear Armor failed to subscribe - NETGEAR Communities
I'd recommend reading through it and trying them.
OilCan
Feb 28, 2021Guide
Okay, just purchased Armor by following these instructions:
- Launch a web browser from a computer or mobile device connected to the Internet.
- Visit armor.netgear.com.
- If prompted, enter your NETGEAR account credentials and click Sign in.
- Click Allow.
Note: By clicking Allow, you are allowing Bitdefender to collect your profile information and email address.
The NETGEAR Armor portal displays.
- Click the menu icon.
- Select My Subscriptions.
- Click Activation Code.
- Enter your activation code.
- Click ACTIVATION CODE
Now, I go into the Nighthawk app. It still says "Activate Trial". I click on it, and it STILL says "Failed to Subscribe". Also checked the browser page for the router, and IT still says "Not Activated" under Armor Security.
Also, the debug file says I don't have a subscription, which isn't true. I've also tried rebooting, and that doesn't help either. Please help.
Please help.
- plemansFeb 28, 2021Guru - Experienced User
- OilCanFeb 28, 2021Guide
Thanks for the reply. I've reached out to Netgear Armor Customer Support and to Christian_R . Tried factory resetting, then reinstalling the android app, all to no avail. Hopefully they can help. :)
- OilCanMar 01, 2021Guide
FYI, my Netgear Armor is now ACTIVE!! :smileyvery-happy: Bitdefender Support Center got in touch with me, they had to modify the subsciption on their side. Thanks for all your help people! :smileyhappy:
- plemansMar 01, 2021Guru - Experienced User
Glad it worked!
