Frank038
Apr 20, 2019Initiate
Netgear Armor access lost after latest firmware update.
I can no long access Armor after the latest firmware update. I paid for the 1 year after the 90 freebie trial. I was always able to get in before the update. Any help would be appreciated.
Than...
Neil53
Apr 27, 2019Star
I have the same problem as every body else I did call netgear was given the tel num for armor they keep telling me they call back every day I call and get the same answer they will callback big ripe off from the company I give any body the number if they like
johnmctech
Apr 28, 2019Guide
My Armor still wont work with the latest firmware. Im tempted to roll back to the previous firmware V1.3.1.44_10.1.23 as I know Armor worked with that release.
- Neil53Apr 28, 2019Star
can you let us know if it works when you try it.
can you let us know if it works when you try rolling it back to old version
- johnmctechApr 28, 2019Guide
Just tried defaulting the router again for the third time and can happily report Armor is working again with the latest firmware. It did however give me the same error again about the 90 day trial however I just selected activate and tried it again and it worked, Armor now enabled and working.
- DexterJBApr 28, 2019NETGEAR Moderator
Hi fatfreddyscat and Neil53, are you still experiencing the issue?
