Frank038
Apr 20, 2019Initiate
Netgear Armor access lost after latest firmware update.
I can no long access Armor after the latest firmware update. I paid for the 1 year after the 90 freebie trial. I was always able to get in before the update. Any help would be appreciated.
Than...
mike-asfaw
May 06, 2019Initiate
"Its not really acceptable for a security solution to fail on a firmware upgrade and have Netgear not take any action or show any concern about it"
My Armour subcription failed on the firmware upgrade. Bitdefender installed through Netgear Armor on all my computers are now disabled/expired even though my account is active. I agree it is unacceptable. I am losing faith in Netgear.
Neil53
May 06, 2019Star
When you do a reinstall you have to make sure that you use the email address that you signed up with if you use a different email address it will not activate the armor account
- fatfreddyscatMay 07, 2019Tutor
I don't think it's really very helpful to keep repeating the obvious here. I for one certainly used the same account and others here did too. There is clearly an issue that goes beyond just user input.
- johnmctechMay 07, 2019GuideI used the same email when I set it up originally and it didn't work until I did a factory default. It's a pain and obviously Netgear have overlooked the Armor feature or they don't care. I bought this product for the Armor and Disney Circle functions
- jaycarMay 11, 2019Aspirant
I have had the same issue
I upgraded my R7000P to V1.3.1.64_10.1.36 today. And my Armor subscription that I have paid for was unable to be reactivated after the upgrade
A factory reset allowed me to reactivate, but this means I had to spend 30-45 minutes returning my router back to my required state
Please can netgear own this issue and fix.
Thanks
