Frank038
Apr 20, 2019Initiate
Netgear Armor access lost after latest firmware update.
I can no long access Armor after the latest firmware update. I paid for the 1 year after the 90 freebie trial. I was always able to get in before the update. Any help would be appreciated.
Than...
Neil53
May 06, 2019Star
When you do a reinstall you have to make sure that you use the email address that you signed up with if you use a different email address it will not activate the armor account
fatfreddyscat
May 07, 2019Tutor
I don't think it's really very helpful to keep repeating the obvious here. I for one certainly used the same account and others here did too. There is clearly an issue that goes beyond just user input.
- johnmctechMay 07, 2019GuideI used the same email when I set it up originally and it didn't work until I did a factory default. It's a pain and obviously Netgear have overlooked the Armor feature or they don't care. I bought this product for the Armor and Disney Circle functions
- jaycarMay 11, 2019Aspirant
I have had the same issue
I upgraded my R7000P to V1.3.1.64_10.1.36 today. And my Armor subscription that I have paid for was unable to be reactivated after the upgrade
A factory reset allowed me to reactivate, but this means I had to spend 30-45 minutes returning my router back to my required state
Please can netgear own this issue and fix.
Thanks
- Orbi-RocMay 11, 2019Luminary
Hi jaycar . Yeah, that's a pain. One way to avoid this with the next update, go to the web portal and sign-on; on the Advanced Tab, click on [Administration] and then
[Backup Settings].
Then click on Backup and you'll find a file called NETGEAR_Orbi.cfg file which you can use to restore your settings once the firmware is updated.
