michalmsz
Aug 15, 2019Follower
NETGEAR Armor activating problem.
Hi, I am traing to sign in to the Neatgear Armor but I this massage poping up: The NETGEAR Armor security activation process failed due to some reason. Please contact Technical Support for m...
DexterJB
Aug 16, 2019NETGEAR Moderator
- squirtstSep 02, 2019Guide
I have the exact same issue happening. Any solution?
- DexterJBSep 02, 2019NETGEAR Moderator
Hi squirtst, we recommend contacting Bitdefender support for a more immediate resolution. You can find their support channels on the link below.
https://www.bitdefender.com/consumer/support/
Dexter
I did, they told me to contact Netgear support.
- Kbnhari_19Aug 23, 2020Aspirant
I am facing the same issue.
- Christian_RAug 28, 2020NETGEAR Employee Retired
Hello Kbnhari_19,
May you send me a private message with your email address and serial number for us to check further.
Thanks,
Christian
- CmarcbiroJan 26, 2021AspirantCan’t activate the security through the app. Speed test does not work while the router clearly works
- vj2444Feb 01, 2021Aspirant
Dear Support,
After factory reset, I won't be able to activate Amor Security.
Please help me!
Kind regards,
Vincent
