michalmsz
Aug 15, 2019Follower
NETGEAR Armor activating problem.
Hi, I am traing to sign in to the Neatgear Armor but I this massage poping up: The NETGEAR Armor security activation process failed due to some reason. Please contact Technical Support for m...
njw5
Jan 07, 2020Tutor
Netgear Armor - activating trial from orbi app fails. Message simply says: Error Failed to Subscribe. click Try Again button and the process simply repeats itself. Can anyone help here? Using IOS with App Version 2.4.12.5, Firmware v2.3.5.30 This looks like this is the only option to activate - doesn't appear I can do it from the netgear website.
DexterJB
Jan 09, 2020NETGEAR Moderator
- njw5Jan 19, 2020Tutor
Thanks for spending your time with Bitdefender's forum asking for assistance. I did receive an email from them 2 days ago apologizing for taking so long to get back with me and saw your log with them. By then I had figured out my own solution to get security installed on the netgear product, so their message back to me was simply stating that they saw my trial period was activated and wanted to know if I still had any issues. Please see my response on this forum as to my solution to what appears to me to have been Netgear problem.
I think I left out the most important step in yesterday's posting - I chose NEW SETUP from the Orbi/Android APP. When I did this, I saw the app installing the security software and I was able to activate. Do you have to reset the router to factory settings? I don't know.
- Kbnhari_19Aug 23, 2020Aspirant
Hi, I am not able to activate the Armor in my Netgear R7000P. Below is the error Message i am getting. Could you please help here?
The NETGEAR Armor security activation process failed due to some reason.Please contact Technical Support for more details."Note : Below are the steps already i had done,1. Factory reset2. Created new account3. Upgrade latest firmware- MrFredCNov 16, 2020Aspirant
I am having the same issue. I cannot activate this service.
- PigletRiderMay 26, 2021Apprentice
I purchased a renewed Netgear Armor subscription through the Nighthawk app (iPhone 7). The purchase went fine. But the renewal failed to activate. All I get on the Nighthawk app on the "A - Security" pane is "Expired - Off." When I click on this pane, it just takes me right back to Bitdefender's website to purchase the renewal, all over again, as if I'd never purchased it.
No matter how I approach this, the app takes me to Bitdefender's site to purchase again, and again, and again. I don't see any way to even deactivate/activate Netgear Armor. I've rebooted the router (via app), not pinhole. I've not deleted and re-installed the app. I'm afraid of loosing all of my device settings/names. I have a lot of them.
If someone has cracked this nut, please let me know. I've also raised this with Bitdefender support. The took some detailed info and said someone would get back to me. That's it.
For my previous post...
