mgdurand1
Mar 17, 2019Luminary
Netgear Armor and another antivirus
Just did the upgrade on my Orbi router and satellites to 2.3.0.32. Gives me the offer to try Armor for 90 days. Did a very little bit of reading and it appears to be a Bitdefender software system t...
- Mar 19, 2019
Hi mgdurand1 ,
Welcome to the community!
That's an excellent question. With NETGEAR Armor, you can use it alongside the Bitdefender Total Security that can be installed on your devices. As this is also an anti-virus software that will share your device system resource, it is best to not have it run with a similar software since it may cause conflicts.
Dexter
Community Team
Mar 17, 2019Guru - Experienced User
I would post here about this:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
