jamesharwell
Sep 01, 2019Aspirant
NetGear Armor and Bitdefender Box 2
Do I need the NetGeat Armor if I have BitDefender Box 2?
myersw
Sep 01, 2019Master
No. I assume you have Bitdefender installed on devices as well. You do that with Armor. Basically Armor and Bitdefender are doing the same or similar things. No need to dupicate. Bitdefender box is probably a better solution anyway.
- jamesharwellSep 02, 2019AspirantThank you for the response. I'm thinking the same as you. I just didn't see any info on bitdefender or netgear's site
