Pfbjr88
Feb 01, 2024Aspirant
Netgear Armor and Bitdefender Security compatibility? AX4200 Nighthawk AX5 5-Stream Wifi 6 Router
I have just purchased or received Nighthawk RAX42 and Nighthawk MR70 and a Nighthawk 1150v Modem! I have Bitdefender Central/Security/VPN subscription. How can I merge or omit Netgear Armor? Is there ...
michaelkenward
Feb 02, 2024Guru - Experienced User
Are you using both the routers on the network?That could cause problems.
What is the Nighthawk 1150v Modem? That's not a Netgear model number.
I have Bitdefender Central/Security/VPN subscription. How can I merge or omit Netgear Armor? Is there any benefits having both( either merged or using)? Should I delete one? Personally, I want to remove armor, I have the best already(basically they're one in the same). What would you do?
Just disable Armor.
Isn't that something that you can do with the Nighthawk App? (I never enabled it on my MR90.)
- Pfbjr88Feb 02, 2024AspirantIDK for sure. I just got it set up and was exploring my options.when I ran onto the armor/ Bitdefender dilemma. The app is about half screwy. I was looking for opinions before I officially posted up on Netgear Tech. Dpt.
Thank you for your assistance.
