Pfbjr88
Feb 01, 2024Aspirant
Netgear Armor and Bitdefender Security compatibility? AX4200 Nighthawk AX5 5-Stream Wifi 6 Router
I have just purchased or received Nighthawk RAX42 and Nighthawk MR70 and a Nighthawk 1150v Modem! I have Bitdefender Central/Security/VPN subscription. How can I merge or omit Netgear Armor? Is there ...
Feb 02, 2024Guru - Experienced User
Pfbjr88
Feb 02, 2024Aspirant
I didn't read the KB. Haven't even looked at it. My answer is yes it can. I'm doing it quite well and efficiently. I have done this for years. We have a large property and the apartment and the main house is spread out. ATM I have ran 2 lines of Cat6e but in the not so distant future I will run optical.(Whenever Spectrum catches up). My thoughts are to get rid of Armor and others agree, I will ASAP.
My equipment is:
NETGEAR Nighthawk MR70 w/MS70
". ". ". " AX 4200 ( RAX42) @aptmt.
Netgear Nighthawk??? CM1150v modem w/voice operating both routers on a single cable line@ 300Mb/s max at the apartment I'm pushing 325Mb/s to 430+ Mb/s.
Thank you all for your assistance. Have a good day!
