jmhga44
Apr 11, 2022Star
NetGear Armor and Western Digital NAS vulnerabilities on RAX 50
My NetGear Armor is continuously detecting vulnerabilities on my Western Digital Mycloud drive even though it is not connected to the Internet (software is out of life). It doesn't seem to detect any...
Retired_Member
Apr 16, 2022Same problem here with my WD MyCloud 6TB. Has detected vulnerabilities since day one of having Armor. I also have the latest MyCloud firmware: 5.21.10, and cloud access is disabled on MyCloud.
Not sure if they are false positives or are unaddressed vulnerabilities by WD.
jmhga44
Apr 16, 2022Star
Thanks for the response. At least I'm not the only one with this situation.
- TopologyApr 18, 2022Virtuoso
Perhaps NETGEAR Armor is detecting the existence of a default username/password for the WD My Cloud device, even if cloud access is disabled?
- Retired_MemberApr 18, 2022
It finds >139 vulnerabilities and I'm not using default authentication
- JeffgearApr 20, 2022Virtuoso
A quick search on the ISC2 vulnerability database shows a few critical vulnerabilities for Western Digital Mycloud. Armor may be detecting indicators related to these vulnerabilities if present on your service. It might be worth following upon the CVEs for the vendor's mitigation guidance.
