jmhga44
Apr 11, 2022Star
NetGear Armor and Western Digital NAS vulnerabilities on RAX 50
My NetGear Armor is continuously detecting vulnerabilities on my Western Digital Mycloud drive even though it is not connected to the Internet (software is out of life). It doesn't seem to detect any...
jmhga44
Apr 16, 2022Star
Thanks for the response. At least I'm not the only one with this situation.
Topology
Apr 18, 2022Virtuoso
Perhaps NETGEAR Armor is detecting the existence of a default username/password for the WD My Cloud device, even if cloud access is disabled?
- Retired_MemberApr 18, 2022
It finds >139 vulnerabilities and I'm not using default authentication
- JeffgearApr 20, 2022Virtuoso
A quick search on the ISC2 vulnerability database shows a few critical vulnerabilities for Western Digital Mycloud. Armor may be detecting indicators related to these vulnerabilities if present on your service. It might be worth following upon the CVEs for the vendor's mitigation guidance.
- jmhga44Apr 21, 2022Star
The vulnerabilities you show in your post seem to be for the WD MyCloud PR4100..that's not the model I have. How did you find those?
