orly6
Aug 21, 2021Follower
Netgear Armor blocking a site but doesn't show URL to allow unblocking
I use PumpSpy to monitor my sump pumps and have never had a problem with receiving messages through my wireless network (PumpSpy only communicates to an associated app through the wireless network, n...
- Sep 08, 2021
Okay, so that seems to have worked. I went to the Netgear Armor page on the web and did as you said. In the notification window, I clicked on the unblock. Then I went to the app and turned off the Armor protection. Reconnected my pumpspy to the network. I decided to put it on my guest network, since it was sending unencrypted data. I'm doubtful if that would cause me issues, but at any rate, I feel safer... Then I turned back on the Armor in the app, and it now seems to be connected without the annoying notifications every 15s. Hopefully, this does the trick and it stays like this. Thank you for all your help on this. It was very frustrating!
timberwolfny
Sep 08, 2021Guide
I found the solution of netgear armor blocking pumpspy is for the user to go to armor security on the app. Than on the time right under notification you will see it blocking the pump spy url and than you just have to click the notifcation and allow it and it will unblock it.
Cannonej76
Sep 08, 2021Tutor
Thank you. Can you clarify what you mean by on the app? Do you mean to click on the Security tile on the Orbi app?
