orly6
Aug 21, 2021Follower
Netgear Armor blocking a site but doesn't show URL to allow unblocking
I use PumpSpy to monitor my sump pumps and have never had a problem with receiving messages through my wireless network (PumpSpy only communicates to an associated app through the wireless network, n...
- Sep 08, 2021
Okay, so that seems to have worked. I went to the Netgear Armor page on the web and did as you said. In the notification window, I clicked on the unblock. Then I went to the app and turned off the Armor protection. Reconnected my pumpspy to the network. I decided to put it on my guest network, since it was sending unencrypted data. I'm doubtful if that would cause me issues, but at any rate, I feel safer... Then I turned back on the Armor in the app, and it now seems to be connected without the annoying notifications every 15s. Hopefully, this does the trick and it stays like this. Thank you for all your help on this. It was very frustrating!
lcourt1
Sep 10, 2021Aspirant
I'm finding this fix is only lasting for a few hours before I have to repeat the process. Is anyone else having a similar experience?
- User987654321Sep 10, 2021Aspirant
Yes, the solution only seems to work for a few hours for most. I reached out to PumpSpy to see if they have contacted Netgear or have any solution. Hopefully, they come up with a resolution soon. If I hear anything, I'll post it. I suggest that more of us reach out them so that they will understand how many people are affected.
