tanveeris
Oct 09, 2021Tutor
Netgear Armor blocking my kids academic website
Hi, I recently enabled Netgear Armor power by Bitdefender on my Router RBR50. It was wokring great until i hit the wall. My Kids academic wesite http://brilliantlms.abcdteacher.com/site/userlogin i...
- Oct 09, 2021
Dear Friends,
I had 1st Gen Cicle Device connected on my network for Parental control. I disbled the Circle and visited the site and noticed i received threat alert with option to unlock the URL.
I suspect Circle was the culprit in my case :)
Oct 09, 2021Guru - Experienced User
have you tried using the app on a different device? LIke if your currently using a android device, try an apple or vice versa?
https://kb.netgear.com/000061032/NETGEAR-Armor-is-blocking-URLs-that-I-want-to-access-what-do-I-do
tanveeris
Oct 09, 2021Tutor
thanks Plemans for for your respose, I am using Iphone for Orbi App to check this case from your suggested point of view i used Samsung S10 Android also. it is same.
the article you shared is correct, unfortunatley i get this unblock option for other thearts links only for my kids acadamic site it does not give me option. I have attached snap shot of threat from Orbi App.
Firmware on Orbi is latest, Mobile Orbi App is latest.
- tanveerisOct 09, 2021Tutor
Dear Friends,
