headlong
Sep 29, 2019Follower
Netgear Armor blocking WeMo functionality
Hi all,
I am finding that when Netgear Armor is enabled I cannot use my WeMo devices. If I disable Armor and reboot the router they all function again. I use a Wemo Bridge hub and it is flagged by Armor as having critical vulnerabilities, and I suspect this is why functionality isn't working. Is there a way to a add a device to an exclusion list or something? Oddly, this did not used to occur when using my Bitdefender BOX which I believe is similar software.
Orbi Firmware Version: V2.3.5.30
Armor Version: v2.18.268-ef914d2
- DexterJBNETGEAR Moderator
Hi headlong, welcome to the community! We recommend reaching out to the Bitdefender support team to have them check on the issue. If you haven't yet, you can contact them on the link below.
https://www.bitdefender.com/consumer/support/
Dexter
