SandSBW
May 04, 2019Follower
Netgear Armor by Bitdefender Subscription
Several weeks ago I signed up for the free trial version of Netgear Armor for my RBR50 Orbi router. Several days ago, I received an email from Netgear Armor offering at 35% discount on a subscriptio...
DexterJB
May 08, 2019NETGEAR Moderator
Hi SandSBW, activating it will end your trial but the activation code does not expire so you can use it at the end of your trial.
Orbi-Roc
May 10, 2019Luminary
Hi DexterJB . Just to make sure I understand this, an activation code is issued by Bitdefender upon purchasing Armor for USD 79/year. Based on your response to SandSBW , the clock doesn't start ticking on the one-year paid Armor subscription UNTIL IT IS ACTIVATED, not from from the purchase transaction date. So if I buy the Armor Netgear license today May 10th but only activate it on June 30th, my one year subcription will start from June 30th. Is that correct?
- garyalbertJun 13, 2019Aspirant
DexterJB - You are mistaken. The PR says the new subscription starts after the trial period but from experince it starts the day you make the purchase. I thought the same but I subscribed with 3 weeks left on the trial (figured it would kick in afterwards) but the clock started ticking the day I made the purchase.
- DexterJBJun 13, 2019NETGEAR Moderator
Hi garyalbert, welcome to the community. If by any chance you have proactively activated your code, then that will end your trial as I have also mentioned in one of the posts above. This link provides the description.
Dexter
