m911762w
Oct 03, 2023Aspirant
Netgear ARMOR disabled [R8000 — Nighthawk X6 AC3200]
R8000 — Nighthawk X6 AC3200 V1.0.4.84_10.1.84 Hello, I wanted to check the device security (mobile phone) on Nighthawk App. When I choosed the device from the list and tap Device Security i fou...
- Oct 04, 2023
Oct 04, 2023Guru - Experienced User
Any progress on this?
V1.0.4.84_10.1.84
Hello,
I wanted to check the device security (mobile phone) on Nighthawk App. When I choosed the device from the list and tap Device Security i found the pop-up "Please enable Armour on your router". So, I logged into my R8000 and checked what's happened. The ARMOR Security is disabled (however I do not disable it) and I could't enable it, the option is locked. My ARMOR subscripion is valid to March, 2024.
What's happened. How can I enable ARMOR on my router?
Thanks,
Mikolaj
