m911762w
Oct 03, 2023Aspirant
Netgear ARMOR disabled [R8000 — Nighthawk X6 AC3200]
R8000 — Nighthawk X6 AC3200 V1.0.4.84_10.1.84 Hello, I wanted to check the device security (mobile phone) on Nighthawk App. When I choosed the device from the list and tap Device Security i fou...
- Oct 04, 2023
m911762w
Oct 04, 2023Aspirant
Any 😞
Oct 04, 2023Guru - Experienced User
What mobile platform are you using? Android or Apple?
What version of the Nighthawk app are you using?
Generally Armor can only be enabled and access thru the NH app. Theres no Armor controls on the routers WEB GUI page.
- m911762wOct 04, 2023AspirantAndroid
App version 2.30.1.3220
When I tapp the Armor icon in the NH app there is a pop up "Unknown error".
When I go to Device Manager, find my device, tapp on it and then tap on Device Security there is another pop up "Please enable Armor on your router" - please find the screen shot from the app attached.
