shanafan
May 03, 2020Apprentice
Netgear Armor doesn't show my router
Hello, I went to check out Netgear Armor's website, and when I signed into my Netgear account, it doesn't show my XR500 router appear. It says "No routers associated with this account." So, I...
Christian_R
May 05, 2020NETGEAR Employee Retired
Hello shanafan,
May you let us know where you purchased your subscription from? (Nighthawk app, website, etc.)
Christian
- shanafanMay 05, 2020ApprenticeThanks Christian. I can’t do anything because it doesn’t see my router so I can’t add the subscription to a device.
Unless I need to buy a subscription first under My Subscriptions on the left?- shanafanMay 06, 2020Apprentice
Here is a screenshot of an error I get when I try to activate Netgear Armor.
- Christian_RMay 06, 2020NETGEAR Employee Retired
Hi shanafan,
Can you clarify if you purchased a subscription or not. If so, from where? Or are you attempting to activate the NETGEAR Armor trial?
Thanks,
Christian
